Assign relaxation to lines / faces / volumes
Assigning a relaxation
To assign a Line, Face, Volume Relaxation to the corresponding geometric entities:
Stage | Action | |
1 | Activate the command Assign relaxation to lines / faces / volumes (see next block) | |
→ | An assignment box is opened. | |
2 |
Complete the assignment box:
→ | The relaxation has been assigned to the selected geometric entities. | |
3 |
Continue the sequence of assignment:
Quit the sequence of assignment:
To activate the command Assign relaxation to lines / faces / volumes, requires the selection of data. Choose one of the methods in the following figure:
