Magnet (unidirectional): demagnetization curve (Hc, Br) + knee
Presentation
This model ( Nonlinear magnet described by H c and the B r module, plus knee adjustment ) defines a nonlinear B(H) dependence with taking into account of demagnetization and knee adjustment .
Main characteristics:
- the mathematical model and the direction of magnetization are dissociated
- a single material for description of several regions
Mathematical model
In the direction of magnetization the model is a combination of a straight line and an arc tangent curve . A coefficient adjusts the shape of the curve knee for a better approximation of the experimental curve
The corresponding mathematical formula is written:
with
where:
- μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
- μr is the relative permeability of material (for H = Hc)
- Hc is the coercive field strength A/m
- a is the knee adjustment coefficient (0 < a and a < > 1)
The smaller the coefficient, the sharper the knee is.
- Js' is computed by dichotomy from Br, Hc and μr, with the equation
The shape of the B(H) dependence in the direction of magnetization is given in the opposite figure.
In transversal directions one can write:
B⊥(H) = μ0μr⊥H⊥
where μr⊥ is the transverse relative permeability
Direction of magnetization
The various possibilities provided to the user are the same ones as those presented in § Magnet (unidirectional): linear approximation.
