Magnet (unidirectional): spline demagnetization curve
Presentation
This model ( Nonlinear magnet described by a spline ) defines a magnet with a nonlinear B(H) characteristic starting from experimental B, H values.
The definition of the B(H) behavior law with this model is a little longer than with the analytic models, but the experimental curve is modeled more accurately.
Main characteristics:
  • the mathematical model and the direction of magnetization are dissociated
  • a single material for description of several regions
Mathematical model
In the direction of magnetization the model is constructed in the following manner:
  • entry of experimental B, H values
  • interpolation by a spline function
The shape of the B(H) dependence in the direction of magnetization is given in the opposite figure.
In transversal directions , one can write:
B⊥(H)= μ0μr⊥H⊥
where μr⊥ is the transverse relative permeability
Direction of magnetization
The various possibilities provided to the user are the same ones as those presented in § Magnet (unidirectional): linear approximation.
