Magnet (vector): linear approximation
Presentation
These models ( Linear magnet described by the Cartesian / cylindrical / spherical vector Br ) define a B(H) dependence of linear demagnetization in Flux (not available in material manager).
Main characteristics:
  • the mathematical model and the direction of magnetization are associated
  • same number of materials and/or coordinate systems than regions
Mathematical model
In the direction of magnetization the model is a straight line.
The corresponding mathematical formula is written as follows:
Β(Η)=μ0μrΗ+ Br
where:
  • μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
  • μr is the relative permeability (recoil line slope)
  • Br is the remanent flux density T
The shape of the B(H) dependence is given in the opposite figure:
Direction of magnetization
The direction of magnetization is “associated” with the model. Three models are provided: Cartesian, cylindrical or spherical vector.
Cartesian magnetization
The mathematical model is the linear model previously described.
The B(H) dependence is defined by the following relationship in a Cartesian coordinate system:
where:
  • is the remanent flux density defined by three components following the three axes of the Cartesian coordinate system: ( Brx, Bry, Brz)
  • μr is the tensor of relative permeability; the three numerical values ( μrx, μry, μrz) correspond to the three axes of the Cartesian coordinate system
Cylindrical magnetization
The B(H) dependence is defined by the following relationship in a cylindrical coordinate system:
where:
  • is the remanent flux density defined by three components following the three axes of the cylindrical coordinate system: ( Brr, Brθ and Brz)
  • μ r is the relative permeability
radial (Brr ) orthoradial (Brθ) axial (Brz)
Spherical magnetization
The B(H) dependence is defined by the following relationship in a spherical coordinate system:
where:
  • is the remanent flux density defined by three components following the three axes of the spherical coordinate system: ( Brr, Brθ et Brφ)
radial (Brr ):
