Step 1 : Creation of the support
Introduction
The method to create the support to carry out a computation of surface magnetic forces on Flux mesh is described in this section.
It is available through the menu
Support creation
The steps in creating the computation support are described below. An image of the creation box for the support is also available.
Step | Action |
1 | Choose the name of the computation support (+ comment) |
2 | Choose the method Support for magnetic surface forces computation |
3 |
Select the Flux geometric entities to create the computation support*:
An automatic filtering exists, refusing the selection of non valid entities |
4 | In case of periodicities / symmetries, choose the application or not of the geometrical rebuilt on the support. |
5 | Choose the mechanical set of the computation support (if existing) |
6 | Validate by OK |
*Tip on computation support selection
Given the existence of an intelligent filter that does not select the invalid elements, one tip is to pass through a constraint region: Choose the regions containing the computation support.
Only the geometric entities verifying the constraint of the method (interface of two different permeability regions) are then selected.
