Step 2: Creation of the force computation and export of the harmonics
Introduction
This section explains how to create a Computation of surface magnetic forces on rotating machine imported mesh.
It is available through the menu
The steps to create the force computation are described below. Images of the creation box are also available.
Step | Action |
1 | Choose the name of the force computation (+comment) |
2 | Choose the method Computation of surface magnetic forces on rotating machine imported mesh |
3 | Choose the support created beforehand |
4 | Define the computation radius in airgap on ¼ distance of the airgap thickness, stator/rotor side, according to where the imported support is (see Computation radius in airgap and slots opening angle) |
5 | Choose the slots opening angle (See Computation radius in airgap and slots opening angle ) |
6 |
Choose the interval of computation according to the choice of applying or not a temporal duplication in the field Data to be computed (see Spatial and temporal definition). Reminders :
7 |
Choose the data to be computed. You must choose :
It is strongly recommended to calculate both forces and harmonics, as the calculation of the harmonics is rapid and necessary to export it |
8 |
Verify if the time interval is in good correlation with :
(see Spatial and temporal definitionSpatial and temporal definition ) |
9 | Validate by OK |
10 |
Re-open the computation box and verify :
11 | Visualize the arrows of the forces or of the harmonics (see Postprocessing with forces arrows ) |
Step 1 to 9 :
Step 10 to 12 :
