Initialization by static calculation: particular cases
General case
The static initialization permits a computation close to reality (without numeric transient) in the cases where there are non-null sources of field at the initial time t = 0 s: magnets, currents (constant, three-phase...)
Particular cases
There are a number of situations in which there are:
  • non-null sources of field at the initial time t = 0 s (as described previously)
  • and a change in the state of the circuit at t = 0 s
    • Contactor (establishment of the voltage at t = 0 s)
    • Closing switch
    • Discharge of capacitor
These particular situations are presented in the blocks below.
Contactor
Contactor with magnet; with establishment of the voltage at t = 0 s :
  • initialization by static calculation allows to take into account the flux generated by the magnets
  • to respect the "assumptions associated with the initialization by static calculation", the voltage should be set at t = 0 + epsilon
    ⇒ voltage is described with the function Valid or the function ValidLR as presented in the figure below
Finite element description: Circuit description:
Coil around the core and the magnet is not represented
U(t) = U0*Valid(t, 1e-8,)
U(t) = U0*ValidLR(t,0, ,0,0)
Switch
Device with magnet, and electrical circuit with a switch closes at t = 0 s :
  • to respect the "assumptions associated with the initialization by static calculation", the switch must be closed at t = 0 + epsilon
    ⇒ see examples below
U0(t) = 48*ValidLR(t,0,,0,0) U0(t) = 5*cos(ω*t)*ValidLR(Time,0,,0,0)
Capacitor
Device with magnet, and electrical circuit with discharge of a capacitor at t = 0s :
  • to respect the "assumptions associated with the initialization by static calculation", you must:
  • add a switch in series with the capacitor
  • open the switch at t = 0 + epsilon
