Multipoint support: definition (structure)
Definition
A multipoint support is defined by:
  • a name
  • a file to be imported
  • a choice between mobile and fix
Name
The name permitting the identification of the multipoint support is given by the user during its creation.
Imported file
A multipoint support is created via the import of a file containing the coordinates of the points. Different formats are available:
Format Description
*.DEX
DEX (= Data Exchange) is a format specific to Flux
*.IP IP is a format for the Fluent software
Tabulated The user manually enters the coordinates of the points
Mobile/ fix support
The user has the possibility to define a fix or mobile multipoint support.
For the choice of a support in motion with a mechanical set, the user will have to define:
  • the mechanical set
  • the position of the mechanical set: choice between the position of reference or the current position
