Energy equation in nanoFluidX is implemented so that it accommodates
        for conduction and convection heat transfer with initial or Dirichlet boundary
        conditions.
            The rate of temperature change of a specific material is given by:
(1)
                With
                     being time,
                     being the temperature,
                     the coefficient of thermal conductivity,
                     the density and
                 the specific heat capacity of the
                material. In SPH form the above analytic expression becomes
(2)
                Where, the indices
                     and
                     standing for so-called owner and neighboring
                particles respectively, and the
                     index is a difference between the respective
                variables of particle
                     and particle
                    . The
                     stands for mass of the particle, the
                     is the gradient of the kernel,
                     is the position vector and
                     is the unit coordinate vector.
            If you want to use the energy transport option, you need to turn the feature on by
                setting the energy_transport flag in Simulation parameters to
                true. Once this step is completed, you can opt for desired output, which can be
                either temperature or rate of temperature change (flux). The code will not work if
                an output is required and the energy transport flag is turned off.
            Finally, set up the phase parameters, which are initial temperature
temp_0) in [K], evolve temperature flag
evolve_temp), specific heat capacity of the material
heat_cap) in [J/kg/K] and heat conduction coefficient of the
                material (
heat_cond) in [W/m/K].
Note: Regarding the
                        evolve_temp flag, this parameter is valid only for
                        WALL or MOVINGWALL phases. If the
                        evolve_temp flag is set to false, or if it is not defined
                    (default is false), the set initial temperature will remain constant throughout
                    the simulation. If set to true, the initial temperature will evolve in time and
                    the temperature of the WALL or MOVINGWALL will
                    be influenced by any surrounding phase. For FLUID phases, the
                    temperature always evolves.
