Viscosity Models
nanoFluidX now supports both temperature-viscosity and non-Newtonian modeling behavior. For temperature-viscosity, three models were implemented: polynomial, Sutherland, and power law. For non-Newtonian, the Cross model is available, which can be used to approximate power law behavior without risking instabilities due to viscosity unboundness of the power model.
Important: Temperature-viscosity and non-Newtonian modeling behavior cannot be used simultaneously. For more information, refer to Viscosity Models in the Command Reference Guide.
Non-Newtonian Viscosity Model (Cross model)
Newtonian fluids, where shear and strain rate have a linear relationship through a single constant called viscosity, are one of the simplest models used to describe fluid behavior. However, some common fluids exhibit more complex behavior where the shearing resistance changes depending on the duration of the shear or the rate of strain applied to the fluid. Some lubricants, many colloidal suspensions, yogurt, ketchup and blood are a few examples of such fluids, collectively called non-Newtonian fluids.
In their simplest form, non-Newtonian fluids may have an effective viscosity that only depends on strain rate without being dependent on the history of the deformation. Also referred to as generalized Newtonian fluids, these simpler non-Newtonian fluids may exhibit shear thickening (dilatant) or shear thinning (pseudoplastic) behaviors with a stress-strain rate relationship of the form for an incompressible fluid.(1)
τ ¯ = 2 μ e ε ˙ ¯ ε ˙ ¯ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaWaaaeaaii aacqWFepaDaaGaeyypa0JaaGOmaiab=X7aTnaaBaaaleaacaWGLbaa beaakmaabmaabaWaaqWaaeaadaadaaqaaiqbew7aLzaacaaaaaGaay 5bSlaawIa7aaGaayjkaiaawMcaamaamaaabaGafqyTduMbaiaaaaaa aa@448B@
Where,
τ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hXdq haaa@37BD@
Stress tensor
ε ˙ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbai aaaaa@37A3@
Strain (shear) rate tensor
μ e ε ˙ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaadwgaaeqaaOWaaeWaaeaacuaH1oqzgaGaaaGaayjk aiaawMcaaaaa@3C07@
Effective viscosity as a function of strain rate
In Cross fluids, the effective viscosity μ e MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaadwgaaeqaaaaa@38C4@ varies smoothly from a predefined zero shear rate viscosity μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ in Pa ⋅ s to an infinite shear rate viscosity μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ in Pa ⋅ s. To control the transition between these two ends, a coefficient 𝑘 [s] and a dimensionless power of 𝑛 are used in the following form to formalize the relationship with shear rate ε ˙ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbai aaaaa@37A3@ in 1/s.
(2)
μ e = μ ∞ + μ 0 − μ ∞ 1 + k ε ˙ ¯ n MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaadwgaaeqaaOGaeyypa0Jae8hVd02aaSbaaSqaaiab g6HiLcqabaGccqGHRaWkdaWcaaqaaiab=X7aTnaaBaaaleaacaaIWa aabeaakiabgkHiTiab=X7aTnaaBaaaleaacqGHEisPaeqaaaGcbaGa aGymaiabgUcaRmaabmaabaGaam4AamaaemaabaWaaWaaaeaacuaH1o qzgaGaaaaaaiaawEa7caGLiWoaaiaawIcacaGLPaaadaahaaWcbeqa aiaad6gaaaaaaaaa@4F1C@
In Cross fluids, shear thickening or shear thinning behavior is achieved by changing μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ and μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ while 𝑘 and 𝑛 control the curve connecting these two values.
In the absence of an explicit definition for reference viscosity, the code will use the maximum value specified for μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ and μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ . This may not be ideal for shear thickening flows as shear rate levels producing the maximum viscosity may not appear in the simulation. It is not recommended to set μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ and/or μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ to zero as this may result in inviscid fluid at certain shear rates. In addition, while it may be possible to use negative μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ , 𝑘 or 𝑛 values without jeopardizing the simulation, these scenarios were not tested and are not recommend as they may result in negative viscosity or viscosity values beyond the interval defined by μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ and μ ∞ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiabg6HiLcqabaaaaa@394B@ . Setting 𝑘 to zero recovers Newtonian behavior with a viscosity value equal to μ 0 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaccaGae8hVd0 2aaSbaaSqaaiaaicdaaeqaaaaa@3894@ .
Temperature-viscosity Models
Temperature-viscosity models are useful when temperature changes significantly influence the viscosity of the fluid. The time-scale of heat transfer in the fluid must be considered in order for these models to exhibit their function. For example, attempting to capture very slow heat transfer dynamics in a complex multiphase flow while having very high resolution and high reference velocities is likely prohibitively, computationally expensive. This feature works best in cases where heat transfer is happening on the same time-scale as the fluid dynamics (low velocity flows) and high temperature gradients are present in the fluid.
Important: In order to enable temperature-viscosity coupling models, both the varvisc_temperature and energy_transport switches in the Simulation Parameters section must be set to true.
There are three temperature-viscosity models available in nanoFluidX:
  1. Polynomial
    Specified by five coefficients (4th order polynomial), such that the dynamic viscosity is given by:(3)
    μ = C 1 + C 2 T + C 3 T 2 + C 4 T 3 + C 5 T 4
    Where,
    T
    Temperature of the particle
    C n
    Coefficients
    For air, the viscosity can be approximated by a linear function with C 1 = 5 × 10 − 8 .
  2. Sutherland law
    Abides by the following expression:(4)
    μ = μ 0 ( T T 0 ) 3 2 ( T 0 + S ) T + S
    Where,
    μ 0
    Reference viscosity
    T 0
    Reference temperature
    S MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape Gaam4uaaaa@36E1@
    Sutherland temperature (coefficient)
    For air, these values are: μ 0 = 1.72 x 10-5Pas, T 0 = 273.15 K and S = 110.4.
  3. Power law
    Defined by:(5)
    μ = μ 0 ( T T 0 ) n
    Where n is the exponent. For air, the power law values are: μ 0 = 1.72 x 10-5 Pas, T 0 = 273.15 K and n = 0.66.
Important:
  • Since the viscosity field is updated after establishing the time step, reference viscosity must be specified in the Domain Parameter section as ref_visc. The reference viscosity should be the highest expected viscosity during the simulation.
  • After the reference viscosity has been set, the Viscosity Models section must be defined.
  • If the varvisc_temperature or varvisc_non_Newtonian options are turned on, it is recommended that all of the fluid phase viscosities in the case be defined in the viscosity models section of the configuration file.
