Launch a Simulation via Windows Terminal
Launch with CMD
Launch with PowerShell
nanoFluidX auxiliaries (nanoFluidX[c], nanoFluidX[p], nanoFluidX[m])
The script set_nFX_environment.bat/.ps1 also sets the
                    environment for the nanoFluidX auxiliaries and they
                    can be run through nanoFluidX[c], nanoFluidX[p], and nanoFluidX[m] (no need for
                        .exe extension) and passing the relevant options. For
                    example:
- nFXc --nfx nfxccase.cfg
- nFXp -i case.cfg
- nFXm -f PATH
