Define Surface Mesh Size
Use the Surface tool to define local mesh settings on selected surfaces.
                Select the surfaces on which to apply the mesh
                    control in the following ways:
- While in the Mesh ribbon, select surfaces, then right-click and select from the context menu.
 - From the Mesh ribbon, click the
                                Surface tool.
Figure 1.Select surfaces.
 - In the dialog, define surface mesh options.
                From the guide bar, execute the command in the following
                    ways:
- Click
 to confirm your selection and remain in the
                            tool.This allows you to continue creating instances and helps you visualize and edit instances with the legend.
 - Click
 to confirm your selection and exit the
                        tool.
 - Click
