Editor Settings
Settings to configure the Editor.
- Annotations
 - Displays a summary of all the templex statements in the file at the top of the text area, and displays a templex statement underneath every parameter.
 - Whitespaces
 - Displays a black dot for all of the spaces and tabs in the file.
 - Line numbers
 - Displays the line number for each line in the file.
 - Overview and cursor position
 - Provides an overview of the open file, and displays a range of selection when you select a string of fields in the file.
 - Column guides
 - Displays column lines.
