Parameter Format Specifiers
When text is selected for replacement with a parameter, the HyperStudy Editor recognizes the format and size of the highlighted text. This specifier controls how the data is written to the file. The formatting should be adjusted as required.
- f
 - Floating point number
 - i
 - Integer
 - e
 - Exponential
 - s
 - String
- %8i
 - An integer printed to be 8 characters wide
 - %7s
 - Prints a string 7 characters wide
- Formatting -5 with %8.5f will result in -5.00000, a floating point number 8 characters wide with precision 5.
 - Formatting 123.456789 with % 8.2e will result in 1.23e+02.Note: When additional precision is needed in field formats like OptiStruct and Nastran, consider using free format the individual line.
- 5.1 formatted as %-8.2 will produce “5.10 “. Note that the quotes in this example are not part of the formatting but used to show the whitespace padding.
The format specifiers in HyperStudy conform to conventional syntax. A more detailed explanation on the syntax can be found in references on computer programming.
