Attach/Detach Parameters from Existing Parameters
                From the menu bar, click Tools > Editor.
                The Editor opens.
 - In the File field, open the file to be used as the base input template.
                Attach/detach parameters.
Option Description Attach parameters to existing parameters Highlight the appropriate fields in the text area, then right-click and select Attach to > varname from the context menu. Detach parameters from existing parameters Highlight the parameter to detach in text area, then right-click and select Detach > varname from the context menu. or
In the row that contains the parameter to detach, click
