poISCL SetN2
Sets the end point for the Stress Characterization Line (SCL).
poISCL_handle SetN2 n2
HyperView Tcl Modify
This command sets the end point for the Stress Characterization Line (SCL).
- n2
 - Node 2.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetN2 node_id_str
hwi CloseStackErrors
None.
