poISCL SetUseIntersections
Specifies whether to use intersections of the path with elements as intermediate points.
poISCL_handle SetUseIntersections option
HyperView Tcl Modify
This command sets the state whether to use intersections of the path with elements as intermediate points. The default value is Off.
- option
 - Use intersections for the Path (true/false).
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetUseIntersections option
hwi CloseStack
None.
