poISweepCtrl GetSelectionSetSize
Gets the set size of the axisymmetry controller.
poISweepCtrl_handle GetSelectionSetSize
HyperView Tcl Query
This command returns the number of parts contained in the selection set within the axisymmetry controller.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
set num [sweep_handle GetSelectionSetSize]
hwi CloseStackErrors
Returns an empty string if an error occurs.
