poISweepCtrl SetEnableState
Enables/disables the state of the axisymmetry controller.
poISweepCtrl_handle SetEnableState state
HyperView Tcl Modify
This command sets the state of the axisymmetry controller.
- state
- The boolean value which controls if axisymmetry will be enabled.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
sweep_handle SetEnableState true
hwi CloseStackErrors
Returns a non-zero value if an error occurs.
