Run Edited .fem files in the Flexbody Prep Wizard
- Open MotionView.
- From the FlexTools menu, select Flex Prep.
- Select the FEA to H3D option.
- Select the Bulk Data file (.fem) that was output from OptiStruct.
- Select the three edited .fem files.
- Specify the name for the .h3d file. Give the file the same name as the original filename, but with the suffix .flex.
- Choose the same interface nodes and modal information as specified earlier.
- Choose the correct units.
- Click Finish.
