MotionView works with a HyperWorks neutral file called H3D to represent the flexible body. This compact file format stores the necessary information for
visualizing the flexbody in the pre-processing window and the modes and interface nodes in the post-processing window.
It also stores the modal and nodal information.
MotionView models solved in MotionSolve or Adams can be animated in HyperView. In addition, the plots for these models can also be viewed in HyperGraph.
