Visualize Modal Deformation, Stress, or Strain Contours
                Click on the Contour button
 on the Result toolbar to display the Contour
                    panel.
             - Select the appropriate Result type and the direction using the drop-down menus.
                Click Apply.
Note: The Stress or Strain results in the flexible body will be available if Stress or Strain was requested while generating the flexible body.
