The powertrain has a set of output requests which gives information about the states and
        the outputs of the powertrain with time. They can be accessed by the Request Subroutine
        POWERTRAIN_REQ with the parameter value of 1, 2, or 3.
    Throttle requests
      Parameter value = 1
                | Component |
                Name |
                Description |
                | X |
                Modulated Throttle |
                The throttle that is applied to the engine after the modulation from the
                  anti-stall system and rev limiter. |
                | Y |
                Input Throttle |
                The original throttle signal that is applied to the model. |
                | Z |
                *Reserved* |
                For future use. |
                | RX |
                Throttle mod indicator |
                If the signal value is 1 then the rev-limiter is cutting the throttle, if it
                  is -1 then the anti-stall system is modulating the throttle, 0 otherwise. |
    Clutch Requests
      Parameter value = 2
Table 1.
                | Component |
                Name |
                Description |
                | X |
                Clutch Slip |
                The clutch slip state. |
                | Y |
                Clutch Slip rate |
                The derivative of the clutch slip state. |
                | Z |
                Clutch Torque |
                The final clutch torque seen at the other end of the powertrain. |
    Engine Requests
      Parameter value = 3
Table 2.
                | Component |
                Name |
                Description |
                | X |
                Engine Speed |
                The engine speed state. |
                | Y |
                Engine RPM |
                The engine speed state in RPM. |
                | Z |
                Engine Torque |
                The torque produced by the engine. |
                | RX |
                Engine Speed Derivative |
                The derivative of the engine speed state. |
