Deformable Surface
                If the Graphics panel is not currently displayed, select the desired graphic by
                    clicking on it in the Project Browser or in the modeling window.
                The Graphics panel is automatically displayed.
                From the Connectivity tab, click the DeformableSurface
                    collector and select a deformable surface from the modeling window, or double click the
                        DeformableSurface collector to open the Model Tree (from which the desired surface can be
                    selected).
                The graphic will consist of a mesh utilizing all of the markers and points from the deformable surface.
 - Click the Properties tab.
 - Enter the number of segments in the U direction (row) for the deformable surface.
 - Enter the number of segments in the V direction (column) for the deformable surface.
