Surface
                If the Graphics panel is not currently displayed, select the desired graphic by
                    clicking on it in the Project Browser or in the modeling window.
                The Graphics panel is automatically displayed.
 - From the Connectivity tab, click the AdvJoint collector and select the advanced joint associated with the graphic from the modeling window, or double click AdvJoint to open the Model Tree (from which the desired joint can be selected).
 - Click the Properties tab.
 - Enter a value for the number of segments in the U direction (row) for the deformable surface.
 - Enter a value for the number of segments in the V direction (column) for the deformable surface.
