This section describes the sequence of actions
      performed by MotionView and MotionSolve when you run the event.
    MotionView
        - Converts any input signals that are accelerations to displacement signals and saves the
          signals to a CSV file saved in the same folder as the acceleration data file.
        - Deactivates the AutoTire systems.
        - Writes the model to the solver input file. The solver input file references the input
          signal files rather than containing the signals.
    MotionSolve
        - Performs a static simulation on the vehicle during which the vehicle’s longitudinal,
          lateral and yaw motions, the steering input, and each wheels’ spin rotation are
          locked.
        - Unlocks the input signal files.
        - Reads the input signal files.
        - Runs a dynamic simulation from time=0.0 to the end time, using Akima’s method to
          interpolate the input signals.
      Note: If the input selected is Force/Moment and the ‘Add Wheel Reaction Forces’ option is
        checked, the reaction forces are evaluated on the tires and applied to the wheels.
