                From the Project Browser, select the system to which the output is to be
                    added.
                Right-click on a system in the Project Browser and select  from the context menu.
OR
                Right-click on an output folder in the Project Browser and select
                        Add Output from the context menu.
                OR
                Right-click the Output button on the
                    General MDL toolbar.
                The Add Output dialog is displayed.
                Specify a label for the output.
                Specify a variable name for the output.
By default, variables names of entities in MotionView follow a certain convention. For example, all
                    output entities have a variable name starting with “tmplt_”. This is the
                    recommended convention to follow when building models in MotionView since it has many advantages in model editing
                    and model manipulation.
                Click OK to close the window or
                        Apply to continue creating entities.
Once an output entity has been added to the model, the panel for the
                    output will automatically be displayed in the panel area.
