Run an Existing Solver File
- From the SolverMode menu, select ADAMS or Abaqus as the solver.
 - In the Run Solver panel, select Run "Solver" file from the radio buttons in the top-left of the panel.
                Click the file browser icon.
                The Open dialog is displayed.
                Select a solver command file to run.
                Note: In the file browser field on the Run Solver panel, the last filename indicated is the default.
 - Click Open.
 - From the Script option menu, select the solver execution script used to run the model.
                Click Run.
                MotionView executes the solver using the command file specified. A message window is displayed monitoring the progress of the solver run.
 - If a report definition is included in the analysis definition when the run is complete, from the Analysis menu, select View Report to add the results of the run to your current session.
