Analysis Tasks - General Entities
                Click Analysis → Task Wizard.
Figure 1.The Task Wizard – Component Analysis window opens.
Figure 2. - Select the required option in the Component tasks drop-down menu and click Next.
                Now you have selected the required analysis data for the model, click
                        Finish button to complete the process and exit Task
                    Wizard.
Figure 3. -
                Select the required options in the Test Rig settings section.
Figure 4. -
                Select Transient or Quasi-Static
                    option from the Simulation Type drop-down menu and select the
                        sinusoidal or swept-sinusoidal
                    option from the Stroke Type drop-down list and enter the required values in the
                    Sinusoidal inputs and Swept sine inputs sections, then click
                        Finish.
Figure 5.It is important to note here that a Transient analysis is needed if you wish to plot damper velocity characteristics.Note: In the component test rig, you can simulate the impact of road excitations on the suspension by selecting one of the options in the Motion type drop-down in the Analysis Wizard. The motion is applied to the axle in the test rig. Currently, the following two options are supported:- Sinusoidal Input
 - Sinusoidal input allows the user to apply a time-invariant
                                    frequency based displacement/velocity to understand the response
                                    of the suspension. The response is governed by the following
                                        equation,
Y=A sin(ωt)
Where, A is the amplitude of the stroke, ω is the constant angular frequency and t is the current time.
 - Swept-Sinusoidal Input
 - Swept sinusoidal input allows the user to apply a time-variant
                                    frequency to the axle. The swept sinusoidal response is governed
                                    by the following equation,
Y=A sin(thetha(t))
where A is the amplitude, and thetha(t) =
Based on the values, input for the start and end time for swept sine analysis by the user, F(t) is considered to vary according to the following equations.
F(t)=0 0<t< tstart
F(t)=ωinit + (ωfinal - ωinit)(t-tstart) tstart < t < tend
F(t) = ωfinal t > tend
For the time starting from tstart to tend, the frequency is assumed to vary linearly from ωinit to ωfinal.
Figure 6.The above graph shows an example of a frequency input where the frequency varies linearly from 1Hz at t=2sec to 7Hz at t=8sec.
