Edit Subsystem Options
When creating the model, edit options exist if you have to modify or recreate the subsystem based on different SEA creations, such as NCTs, Connections, Excitations, Leaks, and so on.
The Edit tool group contains two options that can be used to modify subsystems: split and merge. Use these options to modify a subsystem like Boolean operations.
