Generate Radioss User Libraries
Radioss user libraries are built on Windows and Linux with two different compilers: Intel Fortran or Gfortran.
Radioss UserLib SDK Overview
    userlib_sdk
  ├── linux64_i18.1         : Linux 64 Bit with Intel compiler 2018.1
  ├── linux64               : Linux 64 Bit with Intel Compiler 12.1.3 or Higher
  ├── linux64_gfortran      : Linux 64 Bit with GNU Gfortran 4.4.5 to 4.4.9
  ├── linux64_sp_i18.1      : Linux 64 Bit Single Precision with Intel compiler 2018.1
  ├── linux64_sp            : Linux 64 Bit Single Precision with INTEL Compiler 12.1.3 or Higher
  ├── linux64_sp_gfortran   : Linux 64 Bit Single Precision with GNU Gfortran 4.4.5 or Higher
  ├── win64_i18.1_vs2015    : Windows 64 Bits with INTEL Compiler 2018.1 /
  |                           Microsoft Visual Studio 2015
  ├── win64                 : Windows 64 Bits with INTEL Compiler 12.1.3 or higher
  ├── win64_gfortran_7.2    : Windows 64 Bits with GNU MinGW Fortran 7.2
  ├── win64_gfortran        : Windows 64 Bits with GNU MinGW Fortran 4.9.2
  ├── win64_sp_i18.1_vs2015 : Windows 64 Bits Single Precision
  |                            with INTEL Compiler 2018.1 / Microsoft Visual Studio 2015
  └── win64_sp              : Windows 64 Bits Single Precision with INTEL Compiler 12.1.3 or
                              higher
Each directory contains a static library and a build script.
Prerequesites
OS Version
The recommended operating system is the same as the recommended operating system for Altair Simulation.
Compiler
- Intel Compiler for Linux and Windows
                            - Install Intel Compiler 12.1.2 or 2018.1. Refer to Intel installation instructions. Intel Compiler 2018.1 requires Microsoft Visual Studio 2015. More information can be found at https://software.intel.com/en-us/fortran-compilers
- Gfortran for Linux
                            - Gfortran is embedded in the Linux distribution. Install it using Linux Package installer.
- Gfortran must be version 4.4.5 or higher.
- MinGW Gfortran compiler for Windows
                            - MinGW is a Windows port of the GNU gcc and Gfortran compiler.
- Download MinGW Gfortran at http://sourceforge.net/projects/mingw-w64/.
- Choose the following install options:- Version: 4.92
- Architecture: X86_64
- Thread: win32
- Exception: seh
- Build Revision: Latest
- MinGW Gfortran 7.2 compiler for Windows
- Choose the following install options:- Version: 7.2
- Thread: win32
- Exception: seh
UserLib SDK Installation
SDK Location
The Radioss UserLib SDK is shipped in Altair Simulation installation and located in %ALTAIR_HOME%/hwsolvers/radioss/userlib_sdk
If you received the SDK in a separate package, copy it in your target directory.
Environment Variable Settings
- RAD_USERLIB_SDK_PATH: PATH to SDK ROOT- The following examples were installed with Altair Simulation and - ALTAIR_HOMEenvironment variable set.- Linux (bash):
                                export RAD_USERLIB_SDK_PATH=$ALTAIR_HOME/hwsolvers/radioss/userlib_sdk
- Windows:set RAD_USERLIB_SDK_PATH=%ALTAIR_HOME%\hwsolvers\radioss\userlib_sdk
- Linux (bash):
 The target Architecture Windows/Linux compiler flavor- RAD_USERLIB_ARCH- Linux
                                (bash):export RAD_USERLIB_ARCH=linux64
- Linux
                                (bash):
Generate a Dynamic Library Using the Build Script
Each UserLib version has its own script.
   userlib_sdk
    ├── linux64                 : build_userlib_linux64.sh
    ├── linux64_i18.1           : build_userlib_linux64.sh
    ├── linux64_gfortran        : build_userlib_linux64_gfortran.sh
    ├── linux64_sp              : build_userlib_linux64_sp.sh
    ├── linux64_sp_i18.1        : build_userlib_linux64_sp.sh
    ├── linux64_sp_gfortran_7.2 : build_userlib_linux64_sp_gfortran_7.2.sh
    ├── linux64_sp_gfortran     : build_userlib_linux64_sp_gfortran.sh
    ├── win64_i18.1_vs2015      : build_userlib_win64.bat
    ├── win64                   : build_userlib_win64.bat
    ├── win64_gfortran          : build_userlib_win64_gfortran.bat
    ├── win64_sp_i18.1_vs2015   : build_userlib_win64_sp.bat
    └── win64_sp                : build_userlib_win64_sp.bat
Window Scripts
Scripts
** Generating Radioss Dynamic User Library **
build_userlib_win64.bat /STARTER "Starter source files" /ENGINE "Engine Source files" /LIBRARY "additional static Library" /OUTFILE Library_name [Optional Argument]
[Optional Argument]
/FREE : Source code is in Fortran 90 Free Format
/ADDFLAG "Additional compiler Flags" : Additional compiler flags to set
/LINK_FLAGS "Additional link flags"  : add link Flags like library files to link with.- Script
- Description
- /STARTER
- Starter source files. Add these files in quotation marks.
- /ENGINE
- Engine source files. Add these files in quotation marks.
- /LIBRARY
- Optional. Additional static library for link.
- /OUTFILE
- Optional. A specified library name other than the default.
- /FREE
- Optional. Use this if source code is written in Fortran 95 Free Format.
- /ADDFLAG
- Optional. Use this to set additional compiler flags. Add flags in quotation marks.
- /LINK_FLAGS
- Optional. Advanced users only. Use this to add additional link flags or 3rd party libraries during the dynamic libraries creation phase.
Compiling LAW29 for shells (LECM29.F and SIGEPS29C.F) and Generating a Library with Default Name
F:\>%RAD_USERLIB_SDK_PATH%\%RAD_USERLIB_ARCH%\build_userlib_win64.bat /STARTER "lecm29.F" /ENGINE "sigeps29c.F"
F:\>echo off
Preparing Library
Compiling: lecm29.F
lecm29.F
Compiling: sigeps29c.F
sigeps29c.F
Creating library: libraduser_win64.dll
		Creating library libraduser_win64.lib
		Creating object libraduser_win64.dll
Done
F:\>
Linux Scripts
Scripts
** Generating Radioss Dynamic user library **
Script Usage
build_userlib_linux64.sh starter="Starter source files" engine="Engine Source files" library="Additional static Library" outfile="Optional library name" [Optional Arguments]
-free : Source files are in Fortran 90 Free Format
-addflag "Additional Compiling Arguments" - Advanced Users Only
-link_flags "Additional Linking Arguments" - Advanced Users Only- Script
- Description
- starter
- Starter source files. Add quotation marks if more than one file is set.
- Engine
- Engine source files. Add quotation marks if more than one file is set.
- library
- outfile
- -free
- Use this option if source code is written in Fortran 95 Free Format.
- -addflag””
- Advanced user only. Use this to set additional compiler flags. Add flags in quotation marks.
- -link_flags=“ “
- Advanced users only. Use this to add additional link flags or 3rd party libraries during the dynamic libraries creation phase.
neo DDS/LOI29> $RAD_USERLIB_SDK_PATH/$RAD_USERLIB_ARCH/build_userlib_linux64.sh starter="lecm29.F" engine="sigeps29c.F"
 Compiling:  lecm29.F
Creating library:  libraduser_linux64.so
Done
Generated Library Name
In Windows, the default generated library is named libraduser_win64.dll if /OUTFILE “Alternate library name” is not set.
In Linux, the default generated library is named libraduser_linux64.so if outfile=”Alternate library name” is not set.
Load the User Library
When using the alternate library
                name option, use –dylib [library name] command line argument in
                Starter or Engine subroutines to load the library.
- -dylib [alternate library name]command line argument.
- If RAD_USERLIB_LIBPATH is set, load libraduser_win64.dll or libraduser_linux64.so in the directory defined in this environment variable.
- Load libraduser_win64.dll or libraduser_linux64.so in the local execution directory.
- Load libraduser_win64.dll or libraduser_linux64.so using the %PATH% environment variable (Windows) or $LD_LIBRARY_PATH environment variable (Linux).
A message is printed in the output files when the library is successfully loaded.
EXTERNAL LIBRARY FOR USERS CODE INTERFACE
LIBRARY NAME  . . . . . . . . . . . . . . . . . . . . libraduser_win64.dll
Altair Radioss USERS CODE INTERFACE VERSION  . . . . . . . .1301504220
When user options are used in the Radioss Input Deck, the code in the user library is used.
