Inlet
Identify one or more inlet surfaces and define the conditions.
                On the Fluids ribbon, select the Inlet tool.
 - Select one or more surfaces as the inlets.
                In the microdialog, choose a method to define the inlet conditions.
- Velocity: Define the velocity and direction of the fluid at the inlet surface.
 - Normal Velocity: Define the velocity of the fluid normal to the inlet surface.
 - Average Velocity: Define the average velocity of the fluid at the inlet surface. This method uses a lower velocity near the boundary and a higher velocity near the center of the inlet.
 - Volumetric Flow Rate: Define the volume of fluid that passes per unit of time.
 - Stagnation Pressure: Define the static pressure at a stagnation point in a fluid flow. At a stagnation point, the fluid velocity is 0. In an incompressible flow, the stagnation pressure equals the sum of the free-stream static pressure and the free-stream dynamic pressure.
 - Define the fluid temperature at the inlet.
