Wall
Configure the thermal boundary conditions by defining the temperature, convection, and heat flux.
On the Fluids ribbon, select the Wall tool.
- Select an outlet or surface.
In the microdialog, select a Boundary condition:
- Temperature
- Convection
- Heat Flux
- Based on the boundary condition you selected, follow the relevant steps below.
Temperature
Define the temperature of a selected surface to change the temperature of the fluid when it encounters that surface.
Convection
Define the heat transfer coefficient and ambient temperature of a selected surface to change the temperature of the fluid when it encounters that surface.
- Select one or more surfaces where the convection occurs.
- In the microdialog, enter the HTC (heat transfer coefficient) between the fluid surface and the solid surface.
- Enter the Ambient Temperature of the solid surface.
Heat Flux
Add a flow of energy per unit of area per unit of time to a selected surface to change the fluid's temperature when it encounters that surface.
- Select the surface where you want to add the heat flux.
- In the microdialog, enter the Heat Flux.
