Identify one or more outlet surfaces and define the conditions.
                On the Fluids ribbon, select the Outlet tool.
                Select one or more surfaces as the outlets.
                In the microdialog, define the pressure.
                    Tip: The pressure is defined relative to the
                        atmospheric pressure. To set the outlet pressure equal to the atmospheric
                        pressure, enter 0.
