Result Types for SLM
3D printing analysis for SLM produces results for displacement, plastic strain, von Mises stress, nodal temperature, and temperature.
Displacement
The displacement result type shows how much your model will displace or deflect during the 3D printing process. The areas of the model that are the darkest orange will have the most displacement.
![](../../../images/figures/3Dprint/results_displacement.png)
When reviewing displacement results, you should check that the order of magnitude of the displacement and the shape of the deformation make sense. Use the Animation tools on the Analysis Explorer to view the shape of the deformation.
von Mises Stress
The von Mises stress results can be used to predict part performance and durability. Areas shown in orange/red have exceeded the peak stress.
![](../../../images/figures/3Dprint/results_von_mises_stress.png)
Collision Distance
This result type shows the distance between the printer’s recoater and the top material layer of the printed part. If this distance is less than 0, the recoater will collide with the part when printing.
![](../../../images/figures/3Dprint/results_collision_distance.png)
Layer Shifting
![](../../../images/figures/3Dprint/results_layer_shifting.png)
Failure Index
![](../../../images/figures/3Dprint/results_failure_index.png)
