Bridge
Use the Bridge tool to create a bridge between two or more faces of either the same PolyNURBS cage or different cages.
                On the PolyNURBS ribbon, select the Bridge tool.
 - Click two or more faces.
 - Click the selected faces to create the bridge.
 - Repeat the process to create more bridges. Right-click and mouse through the check mark to exit, or double-right-click.
- Merge two coincident faces by box selecting them and then using the Bridge tool. This technique works well with mirrored parts. You can also use this tool to create a tunnel.
 - You cannot create bridge between two different PolyNURBS parts created at two different points in the construction history timeline. You can, however, edit an existing PolyNURBS construction feature, continue adding PolyNURBS bodies, and then bridge between the bodies instead.
