Export Geometry and Results
Export geometry and simulation results for use in another application.
Export Geometry
Export the entire model using the Save As command, or export selected objects using the Save Selected command.
Export Analysis Results
Export a data deck by clicking the Export button after running an analysis.
In Inspire Extrude Metal, you can analyze metal extrusion, tool deflection, and quenching. In Inspire Extrude Polymer, you can analyze polymer extrusion and tool deflection. Depending on the type of analysis, Inspire Extrude will generate a .grf, .hx, or .fem file.
- After running an analysis using one of the Analysis tools, click the Export button.
- Choose a folder, type a file name, and then click Save.
