Create a Simple Material
Create a simple material with limited parameters.
Simple Material Parameters
Define the color, reflectivity, and roughness.
                    - Color
 - To define the color, choose from the following
                                options:
- Select a color.
 - Select a texture. The texture overrides the color.
 - To blend the color with the texture, click the plus symbol (+). You can tell if the blend option is turned on by looking at the image preview.
To define the shade, enter a value of 0-100, where 100 is the true color and 0 is black.
 - Reflectivity
 - Define the strength of the reflections.
Enter a value of 0-100, where 100 produces perfect mirror reflections and 0 produces the weakest reflections.
 - Roughness
 - Roughness adds texture to the material at a microscopic level. When you
                            modify the roughness, the surface texture still looks the same; however,
                            tiny changes invisible to the naked eye have occurred, affecting
                                reflectivity.
0 can produce a perfect mirror reflection.
Lower values produce crisper and brighter reflections.
Higher values produce blurrier, dimmer reflections. Increasing the roughness spreads and distributes reflections over the surface and creates a more matte surface.
At values approaching 100, light becomes so scattered that reflections are barely visible, if at all.
 - Bump
                            Bump adds texture to the material at a macroscopic level. Because it visibly affects the surface texture, Bump is useful for simulating irregular surfaces.Note: Not all materials have the Bump parameter.
