Specifying the Prediction Resolution, Height, and Network Type
Define the resolution grid, the height where the prediction results are to be calculated, and the type of simulation for the network planning.
The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
This example considers the application of analyzing a Wi-Fi router in a building.
This example considers the application of analyzing the indoor cell-phone reception, set in an urban environment.
This example considers the application of analyzing base stations in a city, set in an urban environment.
This example considers the application of analyzing base stations on hills near a city, set in a rural or suburban hilly terrain.
This example considers the application of analyzing three base stations, set in a building. The network planning simulation is based on a pre-defined air interface file.
This example considers a network planning simulation in ProMan.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Network parameters can be loaded from a predefined .wst file which is available for most of the common wireless technologies.
Define the three base station sites, antennas and carriers.
Launch ProMan in Microsoft Windows using the Feko Launcher utility (which includes WinProp and newFASANT).
Save the new project to file.
Define the first site, place the first omnidirectional antenna at this location, and assign a carrier. The antenna is placed at a height of 2.5 m above ground.
Define the second site, place the second omnidirectional antenna at this location, and assign a carrier. The antenna is placed at a height of 2.5 m above ground.
Define the third site, place the third omnidirectional antenna at this location, and assign a carrier. The antenna is placed at a height of 2.5 m above ground.
Before starting a propagation simulation and a network simulation, define the parameters related to the project.
Specify the parameters for the air interface (wireless standard).
Specify the cell load settings that will be used for interference calculations.
Specify the folder for the network prediction results to be computed using the dominant path model (DPM).
Specify the folder for the propagation prediction results to be computed using the dominant path model (DPM).
The indoor database is solved using the dominant path model (DPM)
Compute the network coverage for the three antennas to obtain the prediction results.
Compute the propagation for the three antennas to obtain the prediction results.
This example showed how to analyze three base stations set in an indoor scenario and to obtain coverage plots using ProMan.
The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
The WallMan component offers a convenient facility to generate and edit vector building databases.
The TuMan tool enables you to generate and modify tunnel scenarios.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
The WinProp utilities consist of the Launcher utility and the Updater.
ON THIS PAGE
ON THIS PAGE
