Overview
Highlights of the new version
- New tests for induction machines with squirrel cage
- Computation and displaying of characterization model maps
- Computation of the efficiency map with scalar control command
- Machines with hairpin winding technology are available in standard mode
- Synchronous machine with permanent magnets
- Reluctance synchronous machine
- Induction machine with squirrel cage
- All the tests are available for machines with hairpin winding technologyNote: The corresponding HyperStudy connectors can be provided for optimization
- Improvement of the test Characterization / Model/Maps for SMPM
- Options have been added to compute and display 1, 2 or 4 quadrants
- Export / System LUT (Activate or PSIM) has been updated for exporting data based on 1, 2 or 4 quadrants
- New export from FluxMotor to Flux2D / FEMT for computing efficiency map with transient application
- Further new functions
- Auto generating the HyperStudy Study in HyperStudy Application
- Solid conductors can be used for machines with skewed topologies (Rotor or Stator), for computation with FluxMotor or while exporting project to Flux Skew.
- The model periodicity (in the back end of Motor Factory) can be considered when the coils, represented with solid conductors are twisted.
| FluxMotor 2022.3 – Highlights |
