Documents to read
Below, here is the list of documents which are available.
1. General user guides for any type of machine:
- Installation_guide_en.pdf (Installation for both Altair® Flux® and Altair® FluxMotor®)
- Supervisor_2022.3.pdf
- MotorCatalog_2022.3.pdf
- PartLibrary_2022.3.pdf
- PartFactory_2022.3.pdf
- Materials_2022.3.pdf
- ScriptFactory_2022.3.pdf
- MotorFactory_2022.3_Introduction.pdf
- MotorFactory_2022.3_3Phase_Winding.pdf
2. User guides dedicated to Synchronous Machines with Permanent Magnets – Inner and Outer Rotor
- MotorFactory_2022.3_SMPM_IOR_3PH_Design.pdf
- MotorFactory_2022.3_SMPM_IOR_3PH_Test_Introduction
- MotorFactory_2022.3_SMPM_IOR_3PH_Test_Characterization.pdf
- MotorFactory_2022.3_SMPM_IOR_3PH_Test_WorkingPoint.pdf
- MotorFactory_2022.3_SMPM_IOR_3PH_Test_PerformanceMapping.pdf
- MotorFactory_2022.3_SMPM_IR_3PH_Test_Mechanics.pdf
- MotorFactory_2022.3_SMPM_IOR_3PH_Export.pdf
3. User guides dedicated to Reluctance Synchronous Machines – Inner Rotor
- MotorFactory_2022.3_SMRSM_IR_3PH_Design.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Test_Introduction.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Test_Characterization.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Test_WorkingPoint.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Test_PerformanceMapping.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Test_Mechanics.pdf
- MotorFactory_2022.3_SMRSM_IR_3PH_Export.pdf
4. User guides dedicated to Induction Machines with Squirrel Cage – Inner and Outer Rotor
- MotorFactory_2022.3_IMSQ_IOR_3PH_Design.pdf
- MotorFactory_2022.3_IMSQ_IOR_3PH_Test_Introduction
- MotorFactory_2022.3_IMSQ_IOR_3PH_Test_Characterization.pdf
- MotorFactory_2022.3_IMSQ_IOR_3PH_Test_WorkingPoint.pdf
- MotorFactory_2022.3_IMSQ_IOR_3PH_Test_PerformanceMapping.pdf
- MotorFactory_2022.3_IMSQ_IR_3PH_Test_Mechanics.pdf
- MotorFactory_2022.3_IMSQ_IOR_3PH_Export.pdf
