Fix Mesh Quality of Tessellated Models
Use the Fix tool to improve the quality of an FE (discrete/mesh) model.
- All selected cleanup operations are performed in sequence using the same order listed in the options menu.
- If you have a CAD geometry model with mesh and you want to improve its quality, first convert it to an FE model using the Convert tool.
