Log File
A log file outputs the HyperLife evaluation summary for a particular run.
A run log file (*.log) is written to the run folder which contains important information about the run setup and status.
- Files imported for setup
- Load history files
- Model file
- Result file
- Analysis type selection
- Type of Fatigue Analysis selected
- Layer information
- Type of loading
- Chosen method
- Events created and the number of repeats assigned
- Selected Parts/Component with the Assigned Material
- Warning
- Evaluation Time
- Query time of input data
- Start time of evaluation
- Percentage of entities evaluated
- End time
- Total Evaluation time
- Result Query Time
