hgtrans control ClearLabelAliasRules
Clears currently defined aliases.
hgtrans control ClearLabelAliasRules subcase, datatype, level
HyperGraphTrans Tcl Clear
This command clears the currently defined aliasing rules for a specificed subcase, datatype, and level.
- subcase
 - The name of the subcase in which to apply the rule.
 - datatype
 - The name of the datatype in which to apply the rule. (Does not apply if the level is “subcase”.)
 - level
 - The level of labels at which to apply the rule.
- datatype
 - request
 - component
hgtrans control AddLabelAliasRule "head" "cabeza" "Subcase 1" "Displacement" request
hgtrans control ClearLabelAliasRules "Subcase 1" "Displacement" request
hgtrans control GetNumberOfLabelAliasRules "Subcase 1" "Displacement" requestErrors
None.
Keywords
get channel alias
