hgtrans control SetTimeScaleFactor
Sets the scale factor for all time channels.
hgtrans control SetTimeScaleFactor value
HyperGraphTrans Tcl Modify
This command sets the scale factor that is applied to time channels. By default, the factor is one.
- value
 - Value must be a positive, non-zero number.
hgtrans control SetFile "ANGACC"
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control SetTimeScaleFactor 1000
hgtrans control StartTranslationErrors
None.
Keywords
set time scale factor
