hgtrans control SetIncrement
Sets the increment between data points translated.
hgtrans control SetIncrement value
HyperGraphTrans Tcl Modify
This command sets the increment between data points read from each channel in the input file. It is primarily used to pair down large data sets.
- value
 - Value must be an integer greater or equal to one. The default values is one (all data points are translated).
hgtrans control SetFile "ANGACC"
hgtrans control SetIncrement 2
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
None.
Keywords
set increment
