hwI3DViewCtrl RotateClockwise
Rotates the model clockwise about an axis perpendicular to the screen.
viewControl_handle RotateClockwise ?angle?
HyperView Tcl Modify
This command allows you to rotate the model clockwise about an axis oriented perpendicular to the screen. The rotation angle, in degrees, can be specified. If it is not specified, the default rotation angle set using the SetRotationAngle command is used.
- angle
 - The rotation angle, in degrees.
 hwi OpenStack;
    variable t [expr rand()];
    catch {
        hwi GetSessionHandle sess$t;
        sess$t GetProjectHandle proj$t;
        proj$t GetPageHandle page$t [proj$t GetActivePage];
        page$t GetWindowHandle win1$t 1;
        page$t GetWindowHandle win2$t 2;
        win1$t GetViewControlHandle vc1$t;
        vc1$t RotateClockwise 15;
    hwi CloseStack;Error
Returns HW_IllegalOp if the client window does not support this command.
