hwI3DViewCtrl RotateRight
Rotates the model right about an axis oriented vertically across the screen.
viewControl_handle RotateRight ?angle?
HyperView Tcl Modify
This command allows you to rotate the model right about an axis oriented vertically across the screen. The rotation angle, in degrees, can be specified. If it is not specified, the default rotation angle set using the SetRotationAngle command is used.
- angle
 - The rotation angle, in degrees.
hwi OpenStack;
    variable t [expr rand()];
    catch {
        hwi GetSessionHandle sess$t;
        sess$t GetProjectHandle proj$t;
        proj$t GetPageHandle page$t [proj$t GetActivePage];
        page$t GetWindowHandle win1$t 1;
        page$t GetWindowHandle win2$t 2;
        win1$t GetViewControlHandle vc1$t;
        vc1$t RotateRight 15;
    hwi CloseStack;Error
Returns HW_IllegalOp if the client window does not support this command.
