hwI3DViewCtrl RotateY
Rotates the 3D plot along the y axis.
hwI3DViewControl_handle RotateY angle
HyperWorks Tcl Modify
This command allows you to rotate or spin a 3D plot along the y axis.
- angle
 - A user-selected number that represents the angle that you want to rotate the 3D plot around the y axis. A negative number indicates a rotation in the negative direction, while a positive number indicates a rotation in the positive direction.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
w1 GetViewControlHandle vc
vc RotateY 45
      Error
Returns success (0) or an error code.
Keywords
HyperWorks
3D plot
Tcl
Modify
