pltIViewControl FitX
Zooms into the x dimensions of the curve in the plot.
hwIViewControl_handle FitX
HyperWorks Tcl Modify
This command zooms into or out of the graph based on the x dimensions of the curve in the plot. It differs from Fit in that it fits only to the x dimensions rather than both the x and y dimensions.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
w1 GetViewControlHandle vc;
vc FitX;
plot Draw
Returns success (0) or an error code.
Keywords
HyperWorks
XY plot
Tcl
Modify
